Easiest way to remove the rear deck? 99 coupe
Old Apr 15, 2008 | 09:01 PM
Colin's Avatar
Default Easiest way to remove the rear deck? 99 coupe
Hey just wondering the best way to get the rear deck off so i can get to the rear speakers? i've looked at it and the only way i can see looks hard as hell. Just wondering if anyones got some bright idea's theyd like to share?
Thanks!
cyberx32's Avatar
Default RE: Easiest way to remove the rear deck? 99 coupe
No easy way lol, its not too hard its just time consuming
Old Apr 16, 2008 | 02:43 PM
imshirazy's Avatar
loosen that black metal thing, then unhinge the clips behind the seats
then the rest is also a bitch since there's overlap with the other decks
Old Apr 16, 2008 | 02:58 PM
dito theres no easy way........ its a HUGE PITA.... so what i would sugest is when you do get it all swaped out then this time mount your new speakers from the botom
Old Apr 16, 2008 | 04:50 PM
imshirazy's Avatar
actually here's an idea
glue or somehow attach a nut to each hole in the 6x9 or w/e speaker choice
that way, you can screw the screw in from the trunk
rather than inside the car
Old Apr 16, 2008 | 05:01 PM
ya thats what i ment.... tho i prefere SHORT self taping screws. a nut thats been glued on can spin.... and then you have to go thru all that trouble again if you ever have problem with the speaker or what not...
Old Apr 17, 2008 | 05:21 AM
PhillipBurch's Avatar
I have a 98 so I dont know how much of a difference there is.
The side panels overlap the rear deck, I was able to bend mine enough to just pull it out.
Putting it back in was no problem. The thing will bend alot without breaking.
Old Apr 17, 2008 | 09:16 AM
Colin's Avatar
K well i'll give all that a try, i really just need to get the bitch to stop rattling every time my subs hit. I dynamated the whole trunk, and its quite as can be, but i spent a lot of money so i'd really like to have no rattling. lol
chandlee190
Nov 9, 2008 05:07 PM
enigma34
May 9, 2008 09:33 AM
batboy
Aug 14, 2007 07:21 AM
xxeddixx
Aug 23, 2006 10:43 AM
deadphishy
Feb 4, 2006 06:14 PM
