boosting my ek...lots of goodies
Old May 11, 2008 | 09:24 AM
civicduty96's Avatar
Default RE: boosting my ek...lots of goodies
it's just a xs manifold.... i had it machined before i put it on.... it's a dsm t25 turbo ..... i had supports welded to the turbo flange to help prevent any cracks from happining..... i dont see why it wont hold up..
i have about $2000 into the setup including the s300 and all the gauges and wideband....
Old May 12, 2008 | 06:09 PM
SovXietday's Avatar
You seriously need to put a bigger turbo on it. That T25 is going to choke it something nasty.
Old May 15, 2008 | 02:59 PM
bcivic's Avatar
how do you like that s300? I plan on using that for my setup. Easy tune? are you using the boost control with it?
Old May 15, 2008 | 07:35 PM
i love the s300.... once we set it up to calabrate with my AEM wide band it was super easy
it also has a self tune program thats pretty badass..... i am setup to run boost control out of pin A17 i belive..... the auto tranns torque converter lockout output..... i used a p28 out of a auto so i would have everthing for boot control..... then a gm selinoid and i'm boosting
i blew a head gasket before i made it to the dyno so now i'm doing it right..... ARP head studs cometic head gasket ,,,,,, and mabe throw some forged cp pistons in my spare ls block and possibly a super 16g
Old May 16, 2008 | 05:46 AM
bcivic's Avatar
nice post some numbers when its done.
Old May 16, 2008 | 05:48 PM
Live_4it's Avatar
hard to believe you only spent $2000 for that whole setup... But it's nice none the less
Old May 16, 2008 | 07:50 PM
well i didnt spend enough... i tore a vac line on my wastegate so i had a boost spike of 17 psi according to the data log on my s300 and blew the head gasket in the process....
so i orderd a .051 cometic head gasket and a set of ARP head bolts.... i was pretty pissed it happend the night before i was supossed to have it dyno tuned.... so the final results will have to wait a little bit
Old May 17, 2008 | 07:02 AM
Live_4it's Avatar
Dam, that sux dude. Those headstuds should help a lot. You could also buy a torque damper, that will help as well with head lift.
Old May 18, 2008 | 08:33 PM
croninc's Avatar
it seems like everyones gasket blows right before the go dyno lol
Old May 21, 2008 | 09:48 PM
2 cracked ring lands and a blown headgasket...... it's time for some forged 8.5:1 pistons
