subs thumping like hart beat! What does lpf, full, hpf mean?
Old May 6, 2008 | 03:06 PM
enigma34's Avatar
Default RE: So, sonic electronix gave me a call.help me!
thtas all it shows and it just got sent to ups. no harness.(((()
Old May 6, 2008 | 04:51 PM
T3rry's Avatar
Member
so you just got the dash it, that's it... dont worry about it, you can get the harness at any place that installs car audio.
Old May 6, 2008 | 05:19 PM
enigma34's Avatar
like walmart? will i get a cheak engine light if i get a harness that dosint have a thing for keyless entry? I want to lose the keyless, if i can get a cheaper harness. Im not buying one from sonic, it will be $16 for shipping..
Will this work and do they sell it at walmart? http://www.sonicelectronix.com/item_...l+HWH-804.html
Old May 6, 2008 | 07:10 PM
gunz4me's Avatar
I ordered a replacement head unit from Crutchfield, and I said that I didn't have keyless because I am ripping the factory radio out and tossing it due to all the nightmares it has caused!
One thing you can do is see if they make a master harness for your particular head unit. They are more expensive, but are plug-n-play! Circuit City and a few other places sell them.
ETA: Something like this: http://www.circuitcity.com/ssm/Metra...oductDetail.do
ETA2: You would also need this if you went the master harness route: http://www.audio-discounters.com/kn16-0001.html
Personally, I only used one ONCE and it ended up being a buttload of wire to have to hide behind the dash in a 90s Dodge Dakota. The only reason I went with it was due to the fact that it was the only thing I could find on a Sunday afternoon.
Old May 7, 2008 | 03:39 AM
enigma34's Avatar
ORIGINAL: gunz4me
Thanks for the city link, i learn that
Two wiring harnesses are required to complete the installation-the vehicle wiring harness and the radio wiring harness. Make sure you have both before you start the installation.
So do i need to buy two? well i know know that i should of said yes to the $33, because now im spending alot more wtf!
so, i gess ill just see what they send me, it says it will be here on the 13th.....
Old May 7, 2008 | 03:51 AM
gunz4me's Avatar
If you want to go the master harness route you usually need two! Every now and again you can run across a master harness that has your vehicle plug on one end and a direct plug for your aftermarket radio on the other end.
You can go the one harness route, but you will need to solder and heatshrink the wires to the aftermarket radio yourself.
Alternative 3 (which I do NOT recommend) is that you can cut the factory plug and wire directly to your aftermarket radio. The reason I do not recommend this is because it is a royal pain to work in certain dashboards after you clip the factory harness and if you ever have to change your radio again it really sucks.
Old May 7, 2008 | 05:23 AM
enigma34's Avatar
ORIGINAL: gunz4me
i dont have a solder, so ill pay for the first option. MASTER HARNESS ROUTE. Where can i get one? And how do i know if the plug will fit into my after market head unit?
Can i you find it all in here in here? i think you posted it, but with to diffrent plases
http://www.sonicelectronix.com/cat_i547_honda.html
Old May 7, 2008 | 05:37 AM
enigma34's Avatar
Aslo i want to take out the tape deck. Will my car look stupid with an empty space down there? i want to remove it because i dont use it and i want to run my ipod cord through the empty space. And probly use it as astorage for my ipod and the cord.Any tips on what i can do?
Old May 7, 2008 | 06:23 AM
gunz4me's Avatar
I don't see the master harness available in that link you provided. Since you don't have access to a solder gun, your next best bet is to get a cheap crimp set and use butt connectors to join your wires together, then consider using electrical tape over the individual connections. Personally, I hate going that route because it seems that one crimp connector will always fail over time, and it is usually the one that causes the most problems (i.e. remote turnon shorts out or every light blows in the dashboard). I used to "fix" professional installs that used crimp connections and failed before I started my career.
As for the Tape Deck, I am planning on leaving mine in there because I thought I had a spare din pocket laying around, and come to find out I think I tossed the dang thing. Also, my cupholder lid is broken and won't close, so I don't really see much of the tape deck. Lastly, I am planning on either routing my iPod cable to the glove box or console to keep it out of sight. But in your case, if you can find a local shop that will sell you a din pocket, you can drill a place for the iPod wire to run through and put some anti slip mat in there to keep it (your iPod) in place.
Old May 7, 2008 | 06:52 AM
KarTuneMan's Avatar
Oh the bliss and excitment of purchasing electronics on line to save a dollar.
