subs thumping like hart beat! What does lpf, full, hpf mean?
ive never used speaker adaptors ive always just cut the wires..... lets face it if your swaping out the crapy stock speakers i dont think youd ever think about puting them back in.LOL
I have evrything hook't up. But im not geting power to the amp!!! I have it wired To the battery and the head unit. It has this light on top of the amp to light up the V for visonik, that is lit up, but the green power button is not!!I disonect the power cable for the battery, and the V is still lit up, so that gets its power from the head unit turn on. So im gessing the problem is the cable to the battery, but i have it hooked up right.
The fuse holder wire is biger than the wire that i have on the other end, could that be the problem?
So, how does everything sound? I am starting off with replacing my door speakers first with some Alpine SPS-600, then my deck speakers (probably some Alpine Type R 6x9s), but I highly doubt I am going too big in the Civic since it is just my daily driver. I "may" add a 4 channel amp to the whole setup down the road then I am calling the sound system done!
MY amp says x-over, and under it has a switch that give's me 3 options lpf, full, and hpf . MY manual doesnt say what it does. I only have the 2 subs hookt to the amp. For best performance what should i haVE IT set at lpf, full,of hpf ?
Y sub was playing fine on the way to school, then it started to thump on its own, with or without music playing. Kind of like a hart beat.. What could it be? Could it be the ground? I just hand screwed it on the spare tire mount,it probly came loose..
ya the ground is probably the bad spot. make sure its clean and clean metal surface and tight!
also the Xcross over is the crossover on the amplifier. LP is for low pass, for subwoofer setup. HP is for HIGH pass which is for more for interior speakers. and FL or FULL is full signal you get high and low frequinces. best option is LP for the sub. and then play with the Hz crossover points to find the best sound to the sub with it pumping away!
also if you dont know what the Xover setting is then im sure your not to sure what the INPUT SENSITIVITY... its not a volume control! it should be matched with what your radios rca output is. if you crank it up it can easily fry your amplifier! if in doubt take it to a audio shop and ask them if they could tune the amplifier settings really quick.
ORIGINAL: addiction2bass
is there a safe side for INPUT SENSITIVITY?
Where is a good plase to ground it, i just want to get it working agian!!!!!!!
dave_57204
Apr 6, 2008 05:38 PM
Narcoleptic724
Dec 3, 2004 08:58 AM
