Tranny rattling
Old May 4, 2005 | 11:52 AM
Liebers's Avatar
Default Tranny rattling
I have a 97 civic lx. I just had a clutch, pressure plate, throwout bering and pilot bushing put in, it still rattles only when im off the clutch, and through all rpms. What do you think?
Also ever since i got the new clutch the pedal is easy to push in and it catches wierd, the clutch was bled right and everything?
Old May 4, 2005 | 12:52 PM
Default RE: Tranny rattling
are you positive that the rattling is coming from your clutch/tranny?
I only ask because i had a major rattling issue with my civic, only happened when I was off the clutch, and it turned out to be a few loosened heat shields. Ripped one off and it improved, still gotta get the rest out. I guess a good way to tell if its just heat shields, is listen closely and see if it only happens when air is moving strong through the exhaust, thats how mine was.
Old May 4, 2005 | 03:56 PM
Liebers's Avatar
its highly doubtful that its a heatshield....i ripped the lower 1s off, the upper one is still on but its not loose
Old May 4, 2005 | 03:58 PM
Liebers's Avatar
this is pretty loud....exactly how loud was yours
Old May 5, 2005 | 06:40 AM
exactly how loud?!? what am i frickin decibel meter? No i'm just kidding man, my heat shield was rattling pretty god damn loud. I don't konw, it was just a suggestion for you to look into. My whole thing is to check out the easy stuff first, cause if you automatically think its something major, then you'll spend way too much time trying to figure it out, only to find that its something simple.
I M O
Old May 5, 2005 | 06:12 PM
Liebers's Avatar
i took the shield off and no luck...guess ill just wait for the swap to replace anything else
Old May 5, 2005 | 11:06 PM
sacicons's Avatar
rebleed the clutch for the engagement issues. its easy to miss a bit of air in there.
Old May 12, 2005 | 04:32 PM
hondabboy's Avatar
if not that then check the tranny see if anything is loose.
malmsteen
Nov 8, 2005 12:20 PM
ItsBobtista
Jun 18, 2005 11:16 PM
tonystark
May 9, 2005 11:15 AM
Forty04
Apr 6, 2005 11:41 AM
Remmy
Feb 6, 2005 03:31 PM
