probably a sad question but...
Old Jun 16, 2005 | 12:52 AM
skimmy_jimmy's Avatar
Default RE: probably a sad question but...
so then i guess my next question would be, whats the difference between sohc dohc?
Old Jun 16, 2005 | 01:01 AM
Nail I3unny's Avatar
SOHC means there is one cam (single over head cam) operating all of the valves on your engine. DOHC (dual overhead cams) means there is a seperate cam for intake valves and exhaust valves
Old Jun 16, 2005 | 01:04 AM
oh alright thanx man. so do you think i should go with the venom 400 or the V-AFC... or could you do both?
Old Jun 16, 2005 | 01:08 AM
Pete's Avatar
idk both? LOL get some mods before u worry about that stuff...........they wont do much for a stock engine.
Old Jun 16, 2005 | 01:11 AM
drop an engine [sm=smiley20.gif]
Old Jun 16, 2005 | 01:20 AM
oh sorry i forgot to list my mods. so far i have a magnaflow exhaust system, dc headers, and weaponR short ram intake.
Old Jun 16, 2005 | 09:16 AM
hondabboy's Avatar
next you should get cams, cam gears, get the head ported and polished, get a AEM fuel rail or which ever, a after market intake manifold either from skunk2 or elb, v-tec controller. those should get you moving pretty strong before turbo.
Old Jun 16, 2005 | 12:15 PM
better yet..pull your engine and get it performance sleaved then make ur bottom end strong as hell. then you could boost it no problem. but get a good bottom end and then work on the top end (valves/valvetrain, cams, polish the header adn maybe get a valve job) then boost it and u'll have one badass SOHC
Old Jun 16, 2005 | 06:19 PM
ha sorry but what do you mean performance sleeve? i guess i dont kno all the indepth things on the engine, all i kno about is like fuel parts, intakes, most the top end parts i guess. and does porting and polishing add alot? i feel like such a f uckin noob[:@]
Old Jun 16, 2005 | 08:48 PM
basically you take your engine in somewhere..they grind down the sleves you have and put new sleves in..and if you want thicker ones then tell them..they will bore it bigger to fit thicker sleves.
