Wiring up dual voice coil subs
I have 2 Audiobahn 12's that are dual voice coil, I have a dual 12" speaker box that has only one terminal for speaker hook up. How do I wire these subs up inside the box?
Counting on you DCA and Remmy! |
RE: Wiring up dual voice coil subs
Depends on what amp you are running and how many ohms each voice coil is. Lemme know that and Ill tell you how to wire it up.
More then likely it will be series each sub and then parallel them to the amp. http://www.precisionautosound.net/2dvcseries.gif |
Nice diagram. Thats pretty much how ya do it. I have more diagrams in the stickies if you wanna take a look at that.
Heres the spec off Audiobahns website on my amp
A5100T 5.1 surround amplifier Class A/B MOSFET — High Current Hybrid Circuitry PWM MOSFET Power Supplies Double-Sided Glass Epoxy Circuit Board THD: 0.02% S/N Ratio: >100dB (+/- 1dB) Frequency Response: 10Hz - 40KHz Variable 18dB High-pass Crossovers: 30Hz - 500Hz Variable 18dB Low-pass Crossovers: 30Hz - 120Hz Center Channel Hi-Pass, Full or Bandpass for Mid-bass Bass boost @ 45Hz: 0-18dB 6-Channel RCA Input Connections 3-way Protection Circuitry: Thermal, Short Circuit and Overload Cooling Fan Cobalt Blue Illumination High Gloss Chrome-Plated Finish Nickel-Plated Block Terminals http://i15.photobucket.com/albums/a3...ridABSpecs.gif |
What is the OHM specs... we dont need all of that.
thats all it tells me
hmm.. we cant really tell unless we get the ohm specs. [&o]
With 4 voice coils total, assuming they're 4 ohm, you're stuck with either a 4 ohm setup (LEVIII's diagram) or a 1 ohm setup (look in sticky for diagram), which your amps says it'll handle.
I think that everyone's asking you for the specs of your subs, not amp to make sure they're 4 ohm voice coils. |
I have the 12's so I guess they are 4ohm coils
http://i15.photobucket.com/albums/a3...ExcurSpecs.gif |
Looks to me like the amp can handle 1 ohm to so hook all the posatives to the 1 posative and all the negs to the one neg and youll be pounding at 1 ohm 800 watts.
| All times are GMT -8. The time now is 01:51 AM. |
