Wiring up dual voice coil subs
I have 2 Audiobahn 12's that are dual voice coil, I have a dual 12" speaker box that has only one terminal for speaker hook up. How do I wire these subs up inside the box?
Counting on you DCA and Remmy!
Depends on what amp you are running and how many ohms each voice coil is. Lemme know that and Ill tell you how to wire it up.
More then likely it will be series each sub and then parallel them to the amp.
Heres the spec off Audiobahns website on my amp
A5100T
5.1 surround amplifier
Class A/B MOSFET — High Current Hybrid Circuitry
PWM MOSFET Power Supplies
Double-Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB (+/- 1dB)
Frequency Response: 10Hz - 40KHz
Variable 18dB High-pass Crossovers: 30Hz - 500Hz
Variable 18dB Low-pass Crossovers: 30Hz - 120Hz
Center Channel Hi-Pass, Full or Bandpass for Mid-bass
Bass boost @ 45Hz: 0-18dB
6-Channel RCA Input Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High Gloss Chrome-Plated Finish
Nickel-Plated Block Terminals
A5100T
THD: 0.02%
Cooling Fan
With 4 voice coils total, assuming they're 4 ohm, you're stuck with either a 4 ohm setup (LEVIII's diagram) or a 1 ohm setup (look in sticky for diagram), which your amps says it'll handle.
I think that everyone's asking you for the specs of your subs, not amp to make sure they're 4 ohm voice coils.
