1997 honda civic cx amp install problems
Old Feb 22, 2013 | 09:40 PM
blindwest49's Avatar
Default 1997 honda civic cx amp install problems
hey guys i just setup my sub and amp today i have everything set, i need to know a few things, i cant find a spot to ground because the ring terminal on my ground cable can only fit 8mm or 10mm screws, so idk what to do there, and i have no idea if my amps turning on, i got a Pioneer GM-5500T and theres no lights, so i got no clue if my remote wire is hooked up to a proper spot, i know about this blue cable with a white line i connected it to that and i got nothing, could that have to do with the ground or is it the wrong cable, help would be appreciated
Old Feb 23, 2013 | 04:56 PM
You have to ground the amp first. If you're installing it in the trunk there should be a usable ground bolt under the back seat. It grounds the fuel pump.
robman1256
Sep 6, 2011 01:49 PM
rduke
Jun 3, 2011 08:47 AM
type-[r]icer
Nov 8, 2009 12:43 PM
Joeln
Mar 12, 2008 10:37 AM
sonicbluezx3
Jul 17, 2006 12:30 PM
