2 P2's for 150?
This is 2004 edition for the p2s 12 inch
P212S4
12" Punch Stage 2, 4 ohm SVC subwoofer with parabolic Injection molded Polypropylene cone, 2" aluminum voice coil former, insulated 16 awg tinsel leads, linear spider, 2" excursion, 60 oz motor structure, removable motor cover, 8 awg compression terminals, optimized for small sealed enclosures, 200 watts RMS/400 watts peak.
$129.99
P212S8
12" Punch Stage 2, 8 ohm SVC subwoofer with parabolic Injection molded Polypropylene cone, 2" aluminum voice coil former, insulated 16 awg tinsel leads, linear spider, 2" excursion, 60 oz motor structure, Cold rolled vented steel basket with removable motor cover, 8 awg compression terminals, optimized for small sealed enclosures, 200 watts RMS/400 watts peak.
$129.99
they are the models for 05 and 06 to.So most like it is 1 of them.so 200 rms 400watts
so If you can find a amp close to 800watts 400rms it will power both speakers.The Xplod I was telling you about would work perfect
P212S4
$129.99
P212S8
$129.99
go get an 800 watt rockford fosgate amp it will sound alot better if you get the same name brand speakers and amp. i have my p1s running on a 650watt rockford amp and they sound better and hit harder than when i had an 800 watt xplod up to them.
^They are right. They are more than likely 200 watts rms a piece. I wouldn't suggest a RF amp to power them though (they are pretty overpriced for what you get). Look for a Class D mono amp from a reputable brand name like Alpine, Eclipse, JBL, Kicker, Orion, MTX, Directed, Kenwood (usually pretty good quality if you're just looking to get a cheaper amp). I definitely would not suggest Sony anything in your car...
Assuming you have the single 4 ohm model, you'll want to wire them together for a 2 ohm load and make sure the power rating on the amp you choose is somewhere close (a little less is okay) to the subwoofers' RMS rating (if they're 200 rms a piece, look for an amp rated at 400 rms @ 2 ohms).
Here's an example of how to wire two single 4 ohm subs (if you've got P212S4 or P210S4 subs):
ORIGINAL: herbaleyes
justinwebb
Oct 29, 2005 12:29 PM
