99 Civic EX front door panel removal
I have door speakers to install into the front door panels. It looks like there are 2 panels on each door. The lower one housing the speaker. I would like to know how to take these off. Do I need to take off the whole door panel or just the lower part. I also don't want to break any clips. I hate that.
[IMG]local://upfiles/27233/992721670F634712AC535DB12787C3C5.jpg[/IMG]
unscrew the door handle. you should be ablt to pull it out disconnect the door lock by pulling the connector out. then push the clip of the metal rod that opens your door movce it to the side of the rod and pull it out. Then it should just be pulling the door panel off. They make a special tool for it but if you don't want to spend money you could just use a flat head and pull the clips from the door. Be careful not to break the clips they are plastic. after you go along the door pulling them all off. then just disconnect the other connectors and thats it.
NickRolando
Dec 29, 2006 10:36 AM
