After market Tach....
Old Apr 30, 2007 | 12:16 AM
Hailchristian's Avatar
Default After market Tach....
Alright......
I have an 88 Civic hatchback with no tach in the cluster..
i got a after market tach for xmas and still have no luck with knowing where to instal it
it has 4 wires...
black - Batery (-)
Red - To Ignition Switch 12 v (+)
Yellow -Battery 12V (+)
Green - on standard ignition green wire attaches to coil negative (-)
so black, yellow, red.....got that part
where on the distributer does the green go...
pictures maybe???????????
any advice would be gracious
Old Apr 30, 2007 | 12:28 AM
civicduty96's Avatar
Default RE: After market Tach....
i believe you just have to tag a spark plug wire...thats how the ones iv'e hooked up worked
i could be wrong though im sure someone else will have an answer for you
Old May 1, 2007 | 01:02 AM
figured it out...
its the blue wire...
Old May 1, 2007 | 04:47 PM
Mad7s's Avatar
What brand and size did you get?
Old May 1, 2007 | 06:04 PM
http://www.glowshiftdirect.com/index...amp;ProdID=193
that one....
glow shift tinted 7 color.
2 1/16"
Old May 1, 2007 | 07:31 PM
BlackDX's Avatar
You can save yourself time and energy by tapping the power, ground, light and tach wire into the wiring harness for the gauge cluster. In the pic bellow the tach wire the #11 solid blue.
This pic is from THIS guide for swapping clusters into EF's.
Old May 1, 2007 | 07:43 PM
YES!!!!!!!!!.....just what i was looking for...
THANK YOU SO MUCH....save lots of time with that
Old May 1, 2007 | 07:55 PM
BlackDX's Avatar
ORIGINAL: Hailchristian
lol yea find it alot nicer to just use the oe wiring than have to run wires all over the damed place. On my 96 dx the previous owner had a 3" sunpro tach installed and the installers ran a tach wire all the way over to the passenger side, thru a grommit and dirrectly to the tach..... but they tapped power off the screw terminals on the back of the gauges... So any time I see these kinds of post I try to search for the OE wiring pics, it's a life saver.
Old May 1, 2007 | 09:28 PM
Strong Island's Avatar
sorry but i have to say thank god you got a small tach like myself.......i hate those huge 5" flava flav clock tachs. especially mounted to the left of the instrument panel, it takes up the whole dam window. i guess people get the big ones so they can see it better but if you need something that big to read you SHOULDNT be driving!!!!!!!!!!!!
Old May 1, 2007 | 09:37 PM
FlipHKD720's Avatar
^ does that diagram work for 6th gens too or is it different?
