buzzing from speakers
right now u hace a single wire that runs to the amp from the radio to turn it on only when the radio is on. what he is saying is disconnect this wire and try "jumpstaring" the amp by wiring up a manual switch.
oooh so if i do that will i be able to turn off the amp and just run off the deck....and how dso i do than what do i run to power ground and the other thing on the swtich
just go to the amp and disconect the remote on wire, it is the really thin one inbetween the power and ground wires. then jupstart the amp by connecting the remote on terminal to the powerwire, using another peice of wire, or switch. then turn on the radio and check for the buzzing
ooh that was much easier said...i kno about this kind of stuff it was just the wording that was confusing...so disconnect the REM and use a pice of wire from the REM on the amp to the power on the amp? and if that solves the problem what do i do because wouldn't leaving it like that have the amp be always on?
ok i tried the thing with the REM line that didn't work...I also tried some things from crutchfield like taking the cd player out of the dash while its still connected to see if its being radiated at that point but that didn't change anything either...i also tried new RCA's but that didn't help....what next?!?!
im not sure if this was asked before, but does it do it when the car is off?, and u only have the key in the acc position. if it only buzzes when the car is on it is most likely a bad alternator, or inadiquit sheilding on your sparkplug wires, are u rinning aftermarket plug wires?
no my spark plugs are the ones that came in the car too and yes it only happens when the engine is running
maybe i need new spark plugs they have about 41k miles on them? could that be it?
