A/C compatibility
Hi, currrently i have a d15 in my '93 del sol. I am going to eventually swap to a b16.
I don't have A/C at the moment, but would like to get it eventually.
I was wondering if i got A/C now, would i have to get one from another d series motor? or a d15, or would any A/C work?
I need lines, and the compressor, only thing i have is the console.
If i cannot use the same A/C for a d15 and a b16, are any of the parts universal? and can be used for both the d15 and b16? ill look for those first.
Thanks.
Thanks.
anything from a 92-95 civic will also fit. but if you get anything from the 95 they are already r134a and the a/c hose and the condensor are a little bit bigger they will work but the hose from a/c comp. and condensor both have to be from 95 if you use them.
the 92-94 came with r-12 which some have been retro fitted but will all bolt up to your motor
00civiclx
Oct 18, 2004 09:55 PM
9295, 95, ac, air, b16, civic, compatibility, compatible, compressors, conditioning, fit, honda, lines, main, series, universal
