cd deck
remove the belly pan (under steering wheel) and remove the glove box. Once you do that, the screws for the center console will be revealed. All you have to do is look for screws that connect dash peices.
yes it will be able to support an amp and subs, you need to get a line level converter (if your amp has one built in, you don't need one), but in my opinion, you should get a better HU first with a pre out for sub, you'll have more control over your sub from the HU and it will have a better sound than with the factory HU.
