CD PLayer Not Turning on
Old Mar 27, 2005 | 12:17 AM
Josh1122's Avatar
Default CD PLayer Not Turning on
Hi i hooked up my CD player and it wont turn on. I have checked both the fuses in CD player and in the fuse box they are fine. What can it be????? Plz Get Back Thx
Old Mar 27, 2005 | 12:54 AM
D16z6's Avatar
Default RE: CD PLayer Not Turning on
maybe the cd player itself??
Old Mar 27, 2005 | 02:12 AM
Remmy's Avatar
It could be d.o.a. But it might be improper wiring. Go to the battery of the car and wire it up there, wire the posi, neg and ignition to the battery, if the cd player doesnt fire up... youve got a dead cd player
Old Mar 28, 2005 | 01:24 AM
Pete's Avatar
Check the ground. A bad ground will prevent it from turning on. Did u use the proper wire harness? Double check wires etc. Most likely a ground......its easy to find a bad ground around the headunit area. If def change the ground first.
FlipHKD720
Jan 25, 2008 01:38 PM
HelpMyHonda
Apr 29, 2007 06:07 PM
da2005pizimp
Feb 7, 2007 11:07 AM
01civicBabygirl
Jun 14, 2006 05:29 PM
Josh1122
Mar 29, 2005 01:43 AM
