Custom Sirius Mount Install
Old Sep 7, 2007 | 07:03 AM
jd352's Avatar
Default Custom Sirius Mount Install
Figured I would show you guys my goal for the week. I did a custom mountSirius Install with a Sportster 4 in a spot better than the ones they offered online. Plus, it cost me less than $1Check it out here are the photos.
If any of you are interested enough, let me know and I will do a DIY for it. It only took about an hour and it was cheap so there ya go.
( I think I embedded the pics right, if not I will have to edit the post)
[IMG]local://upfiles/20501/3585CC1D58444B269D951B0E8CF1BCB3.jpg[/IMG]
[IMG]local://upfiles/20501/51D3699B31574A8B8B11E583232192EA.jpg[/IMG]
[IMG]local://upfiles/20501/ADC5CAB4EEEA4D4DB8C4A25BF176E397.jpg[/IMG]
Old Sep 7, 2007 | 10:58 AM
FlipHKD720's Avatar
Default RE: Custom Sirius Mount Install
oh man super clean, good job!
Old Sep 7, 2007 | 11:12 AM
mill$civic's Avatar
Ya it looks really good, If i got one I would do something like that instead of on the window.
Old Sep 7, 2007 | 11:20 AM
jd352's Avatar
Thanks guys. Next step is to add an additional outlet behind the cover so you dont see it plugged in. I just have to get the additional outlet and the time to do it.
Old Sep 7, 2007 | 05:11 PM
bks85's Avatar
Member
Yeah that's exactly where mine is mounted. It just looks so much better in that spot than up in the window or on top of the dashboard. Plus its less visible to theives and less of a distraction when driving. Too bad I was to lazy to install it myself tho lol
Old Sep 7, 2007 | 05:31 PM
civicduty96's Avatar
ORIGINAL: jd352
what we do at work is hard wire the plug .... then you dont see any wires and dont have to worry about it getting unplugged...
all you have to do is crack the plug open and solder two wires on to the bored then hook em up to a switched 12 volts and a ground and your golden....you have to use the plug because it steps it down to 5 volts..it only takes about 5 minutes to do. just thought i'd throw my 2 cents in...
kjsayers
Dec 20, 2008 11:28 PM
bp4131017
Aug 6, 2007 06:51 PM
Mahones
Jun 4, 2007 05:04 AM
ziggieboi
Jan 27, 2007 01:50 PM
bowhun2r
May 8, 2006 08:52 PM
