Dark Dash
If everything went out at once it's probably the fuse (some models have a separate fuse for the dash lights, on others its the same as the tail light fuse) or the dimmer control. First check that the tail lights and front corner lights on the outside of the car still work. If not, and it's not a fuse, could be the light switch.
Yes the bulbs can be replaced with LEDs.
Everything else works (corners, tails, dimmer, gauge cluster). i'll check the fuse, it might be the bulb, it was dimming 1st then it went out.
Is it extensive work to get behind the dash to change the bulb? just so i know what to expect...
1999cavalierZ24
Jul 12, 2006 01:41 PM
clutchjunkie
May 30, 2005 02:10 AM
