did i dynamat correctly? check out these pics.
Old Aug 27, 2006 | 08:57 PM
Seth2367's Avatar
Default did i dynamat correctly? check out these pics.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
ok so i scored some new polk mmc690 carbon fiber 3-way 6x9 rear deck speakers for my 1997 civic sedan.
[IMG][/IMG]
i put some dynamat around the edges of the place to mount the speakers
[IMG][/IMG]
then i just put the speakers overtop the dynamat and used these little metal mount things to screw the speakers into the rear deck...
so my question...
did i use dynamat right? and i have a lot left over.... what else can i do with it?? thanks guys.
can i just cover the whole rear deck?
also...i have a kenwood 800watt peak and 150x2RMS at 4ohm amp....
the polks are 100RMS and 300max 4ohm... can i hook that amp up to those speakers or will it be way too much power? thanks
Old Aug 27, 2006 | 09:08 PM
lordyrichie's Avatar
Default RE: did i dynamat correctly? check out these pics.
according to my information you have to dynamat the whole rear deck as well as the front speakers too
Old Aug 27, 2006 | 09:10 PM
Seth2367's Avatar
right on man! i'll get on the rear deck tomorrow....but... how would i do the front speakers?
Old Aug 27, 2006 | 09:16 PM
why well u dont have to do it but if u want better sound quality its recommended .
Old Aug 27, 2006 | 09:22 PM
Remmy's Avatar
Not really. You dont have to do the whole deck. I would personally just do mostly the middle and around the speaker cut-outs. The middle is whats going to vibrated. Also, make your your plastic back deck it put down properly because they are famous for rattling.
Old Aug 28, 2006 | 05:41 PM
mill$civic's Avatar
^^+1..i had a problem with the plastic rattling on my car, i had to take it out and add some stuff like dynamat, if you had alot left over...you can also put some around the front speakers
Old Aug 29, 2006 | 05:23 PM
in my opinion dynamat is godo stuff if you do the whole car....
i put some deadener in my truck and it didnt help to much......
so only thing i deaden any more is problem areas! that are rattling and im sure thats the spots rattling!
my speakers i just slaped in and screwed down.
Old Sep 7, 2006 | 07:06 PM
grunge's Avatar
Im new here and I hope you don't mine hearing my opinions. From my experience dynomatting the speakers only isn't going to help much.
The way you have it installed is just reducing vibrational noise, but dynomat has many great things it can do. If you put it only around the speakers your not going to get much of a difference, you need to line the entire rear deck, with it to seal off the trunk from the car.
In my truck which is an extended cab, I have ~150ft of mat, 3 layers on the doors, one on the floor, and one on the rear wall. In a car it would take even more mat to do it real well.
Using dynomat only around the speakers will eliminate vibrational noise, so if you have a problem with that, then thats all you would have to do. If you don't have a vibrational noise problem then its not doing much for you.
Old Sep 7, 2006 | 08:13 PM
not quite true....
it also helps eliminate road noise
Old Sep 8, 2006 | 06:19 AM
mentaldis0rder's Avatar
also helps with direction of soundwaves.. same as theatre panels ... around boxes in and in door panels.. helps your music from fading away
