Did I fry my amp?
Old Jun 26, 2009 | 10:46 PM
Justin13's Avatar
Banned
Default Did I fry my amp?
So i took apart my interior and I figured since it was apart ill hide my sub wires. After that I turned them on and I have it set to play vocals and bass... but this time there was NO bass only vocals. I checked all the settings and wiring and its all how it is supposed to be.
PLEASE HELP
Old Jun 26, 2009 | 11:03 PM
You have one or two amps?
Old Jun 26, 2009 | 11:09 PM
Justin13's Avatar
Banned
1 jensen 460 watt
hooked up to 2 10" ultimates
Old Jun 26, 2009 | 11:13 PM
Superfly's Avatar
check your fuses
did you take the fuse out when working? did it touch anything?
did you hook up the power wire to the amp with the inline fuse still in the power wire?
Old Jun 26, 2009 | 11:18 PM
Justin13's Avatar
Banned
fuses are good
yes / no
yes
Old Jun 26, 2009 | 11:33 PM
Superfly's Avatar
dont ever hook the power wire up with inline fuse still in.
And you have your subs set to play vocals? i'm confused...
Old Jun 26, 2009 | 11:35 PM
Does your amp not have a light on it that tells you if it's working or not? Because if it has a light that's not on, that would rule out a wiring issue between the subs and the amp; if the light's on like normal, it would rule out a wiring problem between the amp and the rest of the car.
Justin13's Avatar
Banned
there is a switch on the amp where i can change it to play vocals AND bass or just bass
Old Jun 26, 2009 | 11:36 PM
You don't want vocals coming through the subs.
Justin13's Avatar
Banned
Does your amp not have a light on it that tells you if it's working or not? Because if it has a light that's not on, that would rule out a wiring issue between the subs and the amp.
yea it has a light but im not sure if its on or not... it has to be tho becuase its playing vocals from the subs or is that just regular power?
