Door speakers
Old Jul 12, 2007 | 04:24 PM
PhillipBurch's Avatar
Default Door speakers
I have a 98 Civic EX and I looked at the speakers in the door panels, and they are the factory ones, and they are really dirty looking, and worn out. While at Wal Mart I found some for a good price, and Im wondering how easy it is to install them.
Old Jul 12, 2007 | 05:07 PM
civicduty96's Avatar
Default RE: Door speakers
it should take about 5 minutes to install the pair .the grills pop off and theres 4 screws then crimp on some female blade terminals and put it back together . left front blue/green is pos and grey / black is neg... right front red/green is pos and brown/ black is neg... hope this helps
Old Jul 12, 2007 | 06:29 PM
Sigracer10's Avatar
depending on how deep the magnet is on the speaker, you may actually have to take the door panel off and cut out the plastic housing that is behind the factory speaker.All you have to do is this:
there is a screw behind the door latch handle. pop off the window switches they are held on by snaps, and i think there is a screw under it. pop off the triangle by the mirror. may have to disconnect the tweeter if you have one. snap off the speaker cover. there are 3 screws surrounding the speaker, as well as four holding the speakers in place. pull the panel away from the door starting from the bottom. and work upward until all the snaps are unsnapped. then pull up on the panel. then proceed to cut of the speaker housing from the panel. preferably with an air saw, but a hack saw will do. put the door back on in reverse and continue to proceed as about for the wiring.
spevie
Jun 22, 2007 11:19 AM
bigedd08
Jul 19, 2005 09:47 AM
Shpadoinkle
May 13, 2005 09:10 PM
MrRocafella
Mar 23, 2005 12:08 AM
1992civicsi
Feb 7, 2005 09:58 AM
