head unit doesnt hold any memory!!!!
hello everybody,
i have a 95 honda civic and had to splice my factory wiring from the radio to my new Pyle PLD53MUT head unit. i wired everything correctly except when i turn the car off the head unit always gets reset...the presets, the volume the eq the clock everything. I have the white/blue(constant) wire connected to the yellow(constant) and the yellow/red(ignition switch) connected to the red(switch) wire but it still doesnt hold the memory!! What is wrong guys!!!?? Please help me out Thank you so much |
Check whether the 7.5 A BACKUP fuse #32 under the hood is blown.
i will check and let you know
thanks RonJ |
If you just recently installed the head unit and the memory has never worked, then you forgot to wire in the memory lead to a constant power source. If you lose your presets, clock preset, and sound shaping settings every time you turn off the vehicle, then it's most likely your memory wire. Check all fuses as well.
As Ron said, the fuse under the hood supplies power to the white/blue constant power wire. When you go cutting wires (not recommended) without disconnecting the battery first (really not recommended), you're almost certain to blow it.
Originally Posted by ej6buddy
(Post 639530)
Originally Posted by mk378
(Post 639532)
Originally Posted by tatman523
(Post 639671)
i did that as stated in my post however i cannot find fuse #32 that ronj speaks of
when you say SLICED..... i hope you mean you bought a wire harness adapter... and didnt cut up your factory harness!
if you did take this for next time... NEVER CUT THE FACTORY WIRES!!!!!!! its the stupidest thing you can ever do with a radio!!!!!!!! spend the 8-15bucks and save yourself ALOT OF HASSLE!!! those wires are color coded and match right up with any aftermarket radio harness. PLUS you can wire them all up inside your house anytime you want and then simply plug it into the stock harness and your deck. when you splice wires you run into alot of problems and its just not worth it. |
(Post 639671)
