Help amp!
It could be overheating or possibly a fuse and also check all of your connections to make sure they are good! I had that problem once! maybe even try disconnecting it for a day then reconnect it and see if that works
ORIGINAL: 01CivicEX
it could be overheating, voltage spiking, or be gettin the wrong impedance. how many ohm stable is the amp and what did you wire the subs at.
This could very much be your problem. Wrong impedence for amplifier. Amplifier may not be able to handle the load you are putting on it.
http://www.the12volt.com/caraudio/wo...igurations.asp
Go here and find out IF you can wire your subs to get the proper "load"
tried all the connections and they seem fine it cant be the impendence issue because they have worked for about a year before and i took em out to built a new box and now they wont work in the new box ne more suggestions?
