Help with amp/speaker set up.
lol...i know i cant spell...
thanks for the help.....and i know im mixing my highs and mids on one line, but i think ill be alright...well see....speakers arn't that expensive and if all else fails I can just end up selling them to my friends that dont no shiit about audio....
Visonik seems to be an ok brand though.....I have 2 amps and they have work perfectly since i got them with no problems and they are made to last....
also...its not a sub on that line...its a mid....6.5" i guess i forgot to put that in my diagram....my 12's will be on another channel and i do have the crossover for the tweeter. IDK....im not to good with audio but im learning and anything is better then the set up i have now. Ill let everyone know how it sounds.....
looking at the diagram you posted, it seems to me you're not running 4 ohms, but only 1 ohm per channel... (it looks like everything is wired in parallel -- 4 4-ohm speakers in parallel will give 1/4 the impedance of one of those speakers)
Now seeing as how this particular amp is a 'bargain basement' amp, I'm assuming it's not 1-ohm stable, which means you'll probably fry it...
Others more knowledgable in car audio than myselfmay come along and correct me, mind you..
M^M
M^M
ORIGINAL: Mr^Man
M^M
M^M
You need 4 6x9s cause i dont wanna build another box...lol
your right...i ment to draw the 6x9s in series with the 6.5 and the tweeter.....
and you just made me realise id be pushing at 4 ohms only giving me 250 w rms from the amp....
so if i get lower rms rated 6x9s...and sonys instead of visonik rated at 40rms and then get some 30 watt rms tweeters instead....that will bring my RMS down to 260 at 4 ohms
so here is the diagram at 4 ohms for reals....lol
and i know this sounds stupid....and it probably is that im mixing everything...but the truth is...im just really cheap....
bass-is-everything
Jul 5, 2011 06:58 PM
driverosp0
Nov 12, 2009 05:41 PM
SMooTHn
Sep 22, 2007 02:48 PM
TurboToyzz
Feb 16, 2007 12:46 AM
