HELP please...
Old Jul 26, 2005 | 09:44 AM
volcom_mike06's Avatar
Default HELP please...
just installed a pioneer amp for my back speakers. the speakers sound great, but there is a continuous high pitched sound coming from the back speakers that increases as my rpms increase, i was told it was my alternator going out... is this correct?
Old Jul 26, 2005 | 10:18 AM
97CivicEX's Avatar
Default RE: HELP please...
sounds like engine noise introduced into your audio system. Do you still have the stock stereo? If so did you use a high to low RCA converter? The farther from the head unit you convert the signal the louder that engine noise will be. So if you converted it at the amp(in the back) it will be really loud, If you convert it in the front next to the stereo it will be pretty quiet. However you can try one of those engine noise suppressors
Old Jul 26, 2005 | 10:36 AM
ngoti 8tor's Avatar
You can also buy an engine noise suppressor or filter as mentioned above.
Old Jul 26, 2005 | 07:32 PM
noops's Avatar
check your gound wired for your amp, make sure you have a good ground
Old Jul 26, 2005 | 07:44 PM
Street Sniper's Avatar
Those noise suppressors suck. It's probably a crappy ground. Did you do the install yourself or did you have someone do it?
Old Jul 27, 2005 | 02:10 PM
BrennanCivic's Avatar
I had the exact same problem when I got a cheap amp off ebay. The only thing I knew to do was buy a small but good amp that didn't produce that effect. I got an MTX, only 200 watts and it was all i needed and i had no problem. You may wanna listen to those other guys tho if u don't wanna just do that. I don't know why a pioneer would give you any problem with that tho. the amp needs a filter for this, so far as i know, but i could be totally off base.
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
dhdicato
Apr 14, 2008 07:25 PM
D16racerchick
Jan 3, 2008 05:15 PM
redridinhood
Oct 9, 2006 07:27 PM
Honda99Civic
Apr 20, 2006 10:13 PM
