Hondata 4bar map sensor
Hey fellas,
When hooking my sensors back up after changing out the headgasket, I accidentally switched the MAP and TPS plugs. Car wouldn't start, and upon switching the two it started with a nasty idle. CEL is showing TPS, MAP, and IACV which is probably off because of the other two. Tried resetting the ECU with no success. My hondata dealer said the proper voltage while the key is turned directly before the ignition position should be around 1.3V. Ground to hot is reading 5V as it should, but Ground to MAP Signal is 1.05V. How should i interpret this data?
________
Washington Marijuana Dispensaries
________
00sithrottle
May 12, 2005 10:25 AM
red_sleeper
Jan 15, 2005 01:08 AM
