hooking up gauges
ok i need help hooking up my gauges. there are 4 wires. (im just talking about how to get them correctly lit up, NOT the sensors....a shop is going to do that) anyways, orange wire - to 12v wire when ignition is on, red wire - to 12v battery wire, white wire - to 12v wire when small lamp on, black wire - ground. so, where do i hook the orange, red, and white to? im pretty sure red is going to go to the positive terminal on the battery, correct? but what about the orange and white?
RE: hooking up gauges
For the orange wire, get a test light and find an empty fuse bus in the fuse box in the cabin, make sure it comes on with the ignition. You can use a fuse tap for that. For the red wire, I'd suggest finding a fuse bus thats on all the time and tapping it, but a wire right to the battery will work too, just look ghetto. White wire, tap into your parking light wire. Use good heat shrinking wire wrap too, butt connectors are kinda dangerous to use on a car's electrical system
so what exactly is the white wire for? i started my car up and tested the gauges out to make sure they worked and i grounded the black wire and hooked the ORANGE wire to the battery. the gauge lit up and worked. this doesnt make any sense to me....and why do i have to tap the white wire into the parking lights? and i have no clue what you are talking about the shrinking wire and all that....
Orange is usually a color for Lume.....That is kinda weird.......
that tells me nothing
lol, I've been search for the same answers as I have a Voltmeter, A/F ratio, and oil pressure. I'll let you know if I find anything...
lol jhs, didnt you answer your own question in the first post?? are are you like looking for confirmation?
Pardon my ignorance, but are there any sites or something that I can read up on the reason of using A/F gauges, oil temp gauges, etc? How would they benifit you?
^ just lets you monitor everything and tells you if anything is going wrong (or right for that matter). An aftermarket tach obviously lets you know if you're revving dangerously high, or tells you when you should shift, a voltmeter tells you how your alternator is working, and there are various other. Shortband a/f ratio gauges dont do much, but if you buy a wideband it lets you accurately monitor how rich/lean you are running, which is crucial (specially for the boosted guys)
These gauges have a memory feature I take it (thus the orange wire for ignition but the red for constant battery).... The white wire is to dimm the gauge so it's less bright at night... I forgot you went big and got high end gauges....
