horn question
Old Mar 2, 2008 | 09:46 PM
tano001's Avatar
Default horn question
Hey guys I am having problems with my horn. It went out and when I press it i hear a clicking noise around the fuse boxes under the driver side. I changed all the fuses and still doesn't work. I even changed the ones under the hood and no luck. Does anyone else know what it can be ? Thanks
Old Mar 3, 2008 | 10:06 AM
ltkenbo's Avatar
Default RE: horn question
Well the clicking is probably the horn relay, it normally does that to trigger the horn you just don't here it over the horn. Your problem is probably with the horn itself. Have you tried changing it or measureing the voltage at the horn when the button is pressed?
Old Mar 3, 2008 | 04:14 PM
tano001's Avatar
nope how would i go about doing that thank you
Old Mar 3, 2008 | 05:39 PM
ltkenbo's Avatar
Pop off the bumper (for easiest access) and have a friend push the horn button and hold a voltmeter across the terminals off the horn. Whenever the buttom is pressed it should read arround 12v. Note: The horn may only have one wire terminal (+) because the - side is usually the mount its connected too since the frame is negative.
Old Mar 3, 2008 | 07:12 PM
Tempe's Avatar
Being that this is an audio forum, I assumed clicking on a topic titled "horn question" that it would be something moreso along these lines:
http://www.hexibase.com/gallery/main.php?g2_itemId=1213
http://gourmetsaint.com.au/Subwoofer/
[sm=shades.gif]
Old Mar 3, 2008 | 07:35 PM
sboarder97km's Avatar
This is not an answer to his question, but how hard is it to change out the horn cause mine just sounds like **** lol.
Old Mar 3, 2008 | 07:42 PM
ltkenbo's Avatar
No that would be the horn effect. And this forum is commonly used for electric stuff too. to change out the horn just remove the old one, put a new one in and connect the wires.
Old Mar 3, 2008 | 07:47 PM
KarTuneMan's Avatar
Get under the car and bang the dirt and crap out of the horns diaphram.
Old Mar 3, 2008 | 08:17 PM
ltkenbo's Avatar
I have a 99 and it doesn't really have a diaphram that can get dirt in it. The diaphram is the whole front of the horn.
Old Mar 6, 2008 | 07:18 AM
KarTuneMan's Avatar
The horn makes noise like a speaker (of sorts) Check it anyways.
