installing l.e.d lights? pain?
Old Aug 12, 2007 | 04:21 PM
point break 92's Avatar
Default installing l.e.d lights? pain?
okay so i bought these http://cgi.ebay.com/ebaymotors/ws/eB...30307&rd=1 and yes go figure the man won't respond. so i have a 92 4 door eg. there are a total of 4 lights 2 small ones on the trunk and 2 big ones on the body. 1 hole in each light available for a bulb in each. 4 light 4 bulb sockets, 4 l.e.d rings .....2 adaptors for a bulb.......now what the hell goes where?? i just need help...that would be awsome
Old Aug 12, 2007 | 04:36 PM
jhsplaya08's Avatar
Default RE: installing l.e.d lights? pain?
just look at your old ones. and as far as the led rings go, just wire them into your brake lights and taillights. i dont really know what you are asking. the reverse lights will go in the taillights that open with the trunk im pretty sure. just experiment with it, you will get it.
Old Aug 12, 2007 | 08:23 PM
BlackDX's Avatar
The issue is those units are full red meaning your reverse light is now useless.
Beyond that I'd say wire the led ring's to the brake input, than use the regular brake bulbs in the reflectors (I'd suggest getting led towers only because those reflector housings don't like heat due to how close they are to the bulb).
Old Aug 13, 2007 | 01:42 AM
Ej1Rider's Avatar
those tail lights are plug and playjust unplug the whole oem connector out of the old tail light, it the whole half of the wiring should come off , all the bulbs and socket comes out with it and you will be left with just the female plugs, then your new tail lights should have a set of the plugs similar to the one your gonna take off, just plug those new ones in bro and should work
Old Aug 13, 2007 | 05:59 AM
i wish they were plug and play, i'm leaving the guy negative feedback right now. lol for saying that. but thanks for the help dudes, i'm wiring them to the brake lights and low beams right now. once again thank you
Old Aug 13, 2007 | 09:22 AM
Ej1Rider's Avatar
^^^ they r plug and play
i just tried explain to you how to do it tho, i guess it sounded like theres alot of work ol sorry dude
gsumano
Jun 21, 2007 08:33 AM
CJ_topdog
Oct 20, 2006 01:24 PM
bladerunner627
May 18, 2006 03:17 PM
xe1002
Aug 22, 2005 09:03 AM
tman
May 7, 2005 08:53 PM
