Last sub/amp question
Here is a picture of my subwoofer (i have two of them in a box, wired together as a mono)
And Here is the amp I got. I got it from a guy I know.
two 10" Pioneer IMPP subs:
Thats the specs (all that I have)
And here is the amp(all I know is it is a d600. I assumed Directed d600) :
http://www.drdetailshop.com/dd600.htm
I am prettypositive that is the amp.
**edit**
I forgot to ask my question. lol
Will these work together? Or is ths amp not good enough?
**edit**
your subs are the wrong ohm load for that amp...you can run one .... you have dual 4 ohm subs so that leaves you with a 1 or a 8 ohm load ... so you'll either get half the power of the amp with your subs in a series or the amp will get pissed off and shut down if there run in a parellel at 1 ohm..... i'd get a 1 ohm stable amp...hope this helps
not sure if thats where you bought that amp... but just a little advice... thats a LOT of money for that amp. If you want to stay cheap and still reliable i'd go with an audiobahn. Most of their mono block amps are stable at 1ohm also.
Nahh, I dont buy anything off the internet. I got that amp from a guy I know, 25 bucks.
Im not even using that amp though, Im getting a Sony one today.
you dont have to post your opinions on Sony, I already know them. Ive read the other threads.
thanks.
thanks.
