My new sound system, still more to add.
Here are my specs on my audio system:
Precision Response 4 x 100W Full Range Digital Amplifier
Specifications:
Power / Channel @ 4ohm 14.4V: 100WRMS x 4
Power / Channel @ 2ohm 14.4V: 150WRMS x 4
Power / Bridged @ 4ohm 14.4V: 300WRMS x 2
Sinal / Noise Ratio: >70dB
Low Pass Filter: 50 - 500Hz @ 12dB/octave
High Pass Filter: 50 - 500Hz @ 12dB/octave
Bass Boost: 0 - 18dB @ 45Hz
Pass Through RCA: Yes
Dimensions: 290(L) x 258(W) x 50(D) mm
Precision Response 800Wrms Class D Amplifier
Power / channel @ 4ohm 14.4V: 400WRMS x 1
Power / channel @ 2ohm 14.4V: 700WRMS x 1
Power / channel @ 1ohm 14.4V: 820WRMS x 1
Signal/Noise ratio: >90dB
Input sensitivity: 200mV - 6V
Low pass filter: 35 - 300Hz @ 12dB/octave
Bass boost: 0 - 18dB @ 30 - 120Hz
Subsonic filter: 10 - 60Hz
Remote level controller: Yes
Dimensions: 324(L) x 258(W) x 50mm(D)
Clarion SRS1626 6" Split System Speakers
200 Watts of Maximum Music Power
6 1/2" Titanium Metallized Mica-Injection Polypropylene Woofer Cone
1" PEI Balanced Drive Tweeter
Powerful Strontium Magnet for Dynamic Bass Response
In-Line -6dB/oct. Crossover Network
Custom Fit Tweeter Brackets Included (Flush, Surface)
GM fit basket design / Chrysler Adaptor Included
12" Precision Response Carbon Fibre Subwoofers[*]Power Handling: 300WRMS[*]Impedance: 4ohms (dual voice coil)[*]Voice Coil Resistance: 1.7ohm[*]Vas: 79.454Ltr[*]Qms: 3.238[*]Qes: 0.446[*]Qts: 0.392[*]Sensitivity: 88.152dB/Wm[*]BL: 9.992 TM[*]Fo: 28.77Hz[*]Sd: 514.720 sqCM
Pioneer DEH-P65BT
[ul][*]MOSFET 50W x 4[*]Bluetooth[*]CD, CD-R, CD-RW, MP3, WMA, WAV[*]2 X RCA Preout[*]Display Illumination - 10-colour LCD[*]Button Illumination - 10 colours[*]IP Bus[*]Aux-in - Rear[/ul]
Spent over $1.7k on it =D haven't put them in yet, will do so when im free. Hope they're as good as its worth =]
Specifications:
Pioneer DEH-P65BT
z6 FoRiLLa
Sep 28, 2005 03:28 PM
