Removing and installing a new head unit
if you search you can find instructions, but basically, what you do is lower down the glove box, lower down the cover under the steering wheel (careful clips!) find 1 screw on each side of the thing underneath the main console area where the accessory is, pull that out, and now you'll have access to get behind the stereo and pull it out, Jason
no, yopu dont need to remove the climate controls, you just need to take out that peice ahead of the shifter where the cup holders are, this will allow you to reach in behind where the stereo is located and push it out, then you'll unplug it and remove it. Just get the under steering wheel piece down, then the glove box, then the piece i was speaking of (where the cupholder, accessory plug are) then you can reach back in there and push out the old HU, if you do a search you may be able to find pictures, so do a net search and someone has it written up somewhere, its not that big a deal, lemme know if you have other questions, Jason
Hey, thanks again Jason!
One more question, then I will let you be... Just so I know what I am in for tomorrow afternoon, are there any screws or bolts to remove once all the panelling is out, or is it really as simple as pulling the old one out and pooping the new one in?
Thanks again!!!
Thanks again!!!
really, thats what i said but i was trying to keep it simple, the climate controls dont have to be removed except for those screws stated above, now getting the new one in is another story, there's wiring to do, both on the new harness and the new stereo, so folloe a wiring diagram and use an aftermarket wiring harness it'll be easier, the civics main wires are labeled, sounds like your in for some fun, i'd only do it on my lunch break if i knew what i was doing, otherwise it'll take longer than that, i kept the explaination simple so he would go and do an internet search to find a real write up, peace
rahh2000
Dec 16, 2009 11:40 PM
head unit doesnt power up anymore and the dash radio seems dim and is always reseting at 1 o'clock..
webucher
May 7, 2008 07:28 AM
Phalcon
Feb 12, 2008 07:22 PM
Bostonhoodhop
Jul 23, 2006 08:17 PM
streetsport85
Jul 18, 2006 09:07 PM
