The right fuse for cathodes?
Old Feb 5, 2008 | 06:26 PM
02CivicLX's Avatar
Default The right fuse for cathodes?
So i've got some cathodes hooked up in my 95 Civic hatch, and i was wondering what rating should i use for the fuse? 10, 15, 20...
[IMG]local://upfiles/16921/FC72467843CD45389CA75056BE2B0815.jpg[/IMG]
Old Feb 5, 2008 | 08:08 PM
02CivicLX's Avatar
Default RE: The right fuse for cathodes?
Any1?
Old Feb 5, 2008 | 08:20 PM
rudedawwg's Avatar
i would do a 7.5
Old Feb 5, 2008 | 11:14 PM
FlipHKD720's Avatar
i've had them on 10 and 7.5 and both have worked fine.
Old Feb 6, 2008 | 10:37 AM
The current that each lamp set uses should be on the package or the label. If the manufacturer spec'd them in mA (milliamps), divide that number by 1000 to get amps. Total up the rated amps of all the lights on the circuit and then use a fuse about double that size. For example 4 units at 800 mA each = 4 x 0.800 A = 3.2 A, use a 7.5 amp fuse.
The key thing is that all the wiring needs to be large enough to handle the fuse current, that way if there's an overload the fuse will blow instead of the wires burning.
Old Feb 6, 2008 | 10:43 AM
FlipHKD720's Avatar
the cathodes also have a transormer that comes with them, so you need to find the right amperage for the transformer. The wires between the cathodes and the transformer are different.
badb0ybilly
Mar 14, 2007 01:34 PM
FlipHKD720
Feb 12, 2007 09:55 AM
badb0ybilly
Feb 6, 2007 03:49 PM
LudaKris613
Aug 19, 2006 08:39 AM
01silverbullet
Aug 18, 2006 08:27 PM
