speakers
Old Mar 6, 2006 | 12:33 PM
silvercivicex98's Avatar
Default speakers
how do i get the speakers out of a 1998 civic in the rear, i see that i need to get the stock grill off first but how do i do this?
Old Mar 6, 2006 | 12:48 PM
psychocivic's Avatar
Default RE: speakers
in the trunk, around where the speakers come down there are bolts that are holding the grill in place. and the bolts for the speakers are right there too. when you crawl in your trunk and look you'll see what i'm talking about. just take the nuts off and they're free.
Old Mar 6, 2006 | 01:16 PM
Remmy's Avatar
^ wrong.
You have to dissasembple the back dash. PLEASE see the DIY on it. I have one specifically for 4 dours but the same applies to coupes also.
Old Mar 7, 2006 | 10:41 AM
Raul98's Avatar
you have to remove the rear deck start by disconnecting your 3rd brake light connection. You have a bunch of clips you will have to remove be careful not to brake too many of them I say too many cause when I did mine i broke 2 of them. From there you have to play with the deck pulling lifting here and there until you can remove the deck cpmpletely. Seems harder than it really is didnt take me too long to remove it. Once the deck is off you will see the screws holding down your speakers just unscrew them drop in your 6x9 and screw them back in. Then you have to lay the deck back on which to me was a bit harder than removing it.....
good luck I know this explanacion is not too clear but once you get started you will see its not that hard to do....
Old Mar 7, 2006 | 01:05 PM
Solid_Snake's Avatar
I'll post a DIY for a 96-00 Coupe rear speaker installation in a couple of mins, it is not the same as the sedan, the sedan is easier [:'(]
Old Mar 7, 2006 | 01:28 PM
Raul98's Avatar
didnt know it was different
cool post that DIY wanna see whaty the difference is
Old Mar 7, 2006 | 02:00 PM
Remmy's Avatar
Its similar... same concept though.
Old Mar 7, 2006 | 03:58 PM
okie i was wrong lol. but when i had my 99 ex 4 door, thats how i had to do things. i dunno why but oh well.
Old Mar 7, 2006 | 10:11 PM
in the coupe, its easier when you remove the side panels, which is also easy but a little time consuming, if you decide to not to remove the side panels, removing and installing the rear deck is a PITA
spevie
Jun 22, 2007 11:19 AM
00civiclx
Sep 30, 2004 04:48 PM
00civiclx
Sep 29, 2004 11:35 PM
HELEN SYLK
Jun 7, 2004 06:14 PM
OCH Orange County Honda
May 25, 2004 08:58 PM
