Sub problem...
Old Jul 2, 2006 | 02:04 PM
hondaaada's Avatar
Default Sub problem...
my sub has been randomly shutting down in the middle of songs for short periods of time. it happens maybe once every 45 seconds and lasts for about 5-10 seconds. it also seems to happen when the volume is up higher. i'm running an infinity basslink II with a basic panasonic deck (50w x 4). if anyone has any ideas what the problem could be (loose wires, not enough power,etc.) i'd love to hear! thanks.
Old Jul 2, 2006 | 02:06 PM
pWnEdU's Avatar
Default RE: Sub problem...
It may be the overheat circuit.
Old Jul 2, 2006 | 05:44 PM
Pete's Avatar
I doubt its an overheating circuit. Chances are its lacking power. First of all check the amps ground....make sure its a good solid ground and that all the paint is scraped off of the surface, so the gold plated connector is touching METAL. What gauge wire are you using, and what kind of electronics....wattage would be nice too. I would first check the ground.....is the amp bridged? The sub may be too powerful for the amp.....let me know
Old Jul 2, 2006 | 07:55 PM
Remmy's Avatar
^ Pete hit the nail on the head. Its a wiring problem. Your amp is only shutting down to protect itself. disconnect the remote wire immediatly and remove the fuse in the power line until you get a chance to sit down with it.
Old Jul 3, 2006 | 12:18 AM
padresfan1988's Avatar
As he said, its a infinity basslink, it has a built in amp. The amp that is built in should be the perfect amp for the sub. But just like pete said, check your ground, and make sure your running at least 8awg power wire.
Old Jul 3, 2006 | 01:46 AM
hondaaada's Avatar
like padresfan said it's a basslink so it's a sub/amp combo, i would imagine they would be a good match. i will check the ground though and let you guys know what happens, thanks.
Old Jul 3, 2006 | 09:44 AM
Remmy's Avatar
Where the ground is connected...make sure you thoroughly scrape the paint off. That is one of the most common issues.
Old Jul 3, 2006 | 02:37 PM
hondaaada's Avatar
well i tried reconnecting the ground and scraping some more paint off and it doesnt seem to have helped. Is it possible that I'm pushing it too hard, i have the gain all the way up and the remote all the way up. Any ideas?
Old Jul 3, 2006 | 02:48 PM
neon3kgt's Avatar
yeah you could be pushing it too hard. does the amp get really hot?
Old Jul 4, 2006 | 12:36 PM
hondaaada's Avatar
havent really checked how hot it gets, i'll check next time
