Sum help please...
Old Jan 7, 2006 | 11:19 PM
mxs's Avatar
mxs
Default RE: Sum help please...
You can put a switch inline, to disable it when you have to leave your car in gear (if you're parking on a hill) or if you are going to give the keys to someone else.
Old Jan 7, 2006 | 11:57 PM
Pete's Avatar
When you install an auto starter in a 5 speed it just bypasses the clutch. So even when you use your key to start the car you dont have to step on the clutch.
Old Jan 8, 2006 | 10:15 PM
fastman90's Avatar
Yeah, once you get the remote start install done right in a 5sp it usually works just as good as an auto considering it just bypasses the clutch like pcupo said. There were a few times this winter when i definately wouldnt have minded walking to a car that had already been warming up for a few minutes.
Good luck with all of it though!
Old Jan 9, 2006 | 02:53 PM
01CivicEX's Avatar
Ok yeah i understand what all of you are saying about it being unsafe and all but im not going to install it until i put in a neutral safety switch, which allows the car to start only when in neutral, regardless of the clutch position (even tho i will have to bypass it). ONce u start doing it its not all that hard.
Old Jan 9, 2006 | 03:29 PM
Remmy's Avatar
There is some sort of clutch sensor that stop ytou from doing it. It is very possible to put remote start on a manual. Ive seen it done. But (lmao) if you leave it in gear, just his the button and watch your car go!
badar_VTi
May 6, 2010 12:48 PM
jerzy_kid87
Dec 23, 2009 11:28 AM
Hatchness135
Jul 25, 2006 10:33 AM
01CivicEX
Jul 15, 2006 02:44 PM
Josh
Oct 24, 2005 12:05 PM
