Upgrade system
Well I think my subs blew because when I hook them up they make a initial hit, but very very very low like you have to be absolutley quiet to hear it, not a intial boom. But yea I want to replace them with 12's and probably gonna need a new amp.
Any sites or places that have deals on boxes, subs and amps? I want a ported box also. So anyone help me build a system.
Hmm, this is tough to say. First off, if you want something that hits harder, 600 watts RMS from that MRP-650 isn't going to do much, unless you want to run a single sub... But I see you are looking to replace the amp.....
I would recommend a pair of SPL 12s and a lot more power to satisfy your hip-hop bass desires. I heard a pair of Digital Designs 3512 subs in a Scion TC off of 700 watts RMS each, and stuff would fall through the headliner with the volume cranked all the way up. The RE SE series - http://reaudio.com/home.html - is also a good balance between playing loud and sounding good. Another good selection would be some AudioQue subs and one of their amps: http://www.audioque.com/aq/index.htm
Granted there are other subwoofers out there that will play loud and low too.... I just wanted to get you pointed in a direction
ETA: I generally recommend staying far, FAR away from pre-fab enclosures, especially ported. You are way better off either building or having someone build a custom enclosure for your vehicle and your subwoofers.
it really depends on how much you want to spend.
Audioque is great if you want loud and decent SQ for cheap
I own two SDCs and the AQ1200D, and i can guarantee they will murder your Infinitys.
SSA, Fi, Mach 5 audio, Ascendant Audio, Digital designs and anything from here
http://www.soundsolutionsaudio.com/z...=index&cPath=2
I own two SDCs and the AQ1200D, and i can guarantee they will murder your Infinitys.SSA, Fi, Mach 5 audio, Ascendant Audio, Digital designs and anything from here
What kind of places would build a box though, I def dont want to try to build one myself. You think just a local audio place would do a good job, ie not a franchise store. I was looking to spend about 500-600 but would be willing to do a little bit more like 750+
Also Im worried about if I can run all my stuff with my current battery and alternator, I put in some 0 guage in the trunk and except I couldnt run 0 guage from the alt to the battery because it would just cause the top of the battery post to melt on the negative part when i put the ground on the negative, the rest of the car is 4 guage.
Yea I was disappointed with my infinitys, maybe it was on my end or just because they are 10s, but they deff did not hit as hard as I thought.
Alright alright so I figured out that one of my subs still work... just will take my amp into safe mode when i hook up both, apparently something is really messed up with the other sub. So I can get another sub from a friend for dirt cheap and maybe get another amp.
But is there a way I can get a rca splitter, rca cable (Or whatever) to go to two different amps but put out the same noise. I want to have the two 10's run on two different mono channel amps until I really feel like dishin full out for the total upgrade.
i don't know if it's recommended though, but i don't see why not.
it's called a y-adapter. you'll need 2 y-adapters (with one female, two males on each y adapter) and 2 dual rca cables.
