WTF HAPPENED? SYSTEM
Old Oct 22, 2007 | 12:34 PM
s0ulj3r's Avatar
Default WTF HAPPENED? SYSTEM
I wired up my system yesterday for the first time, they're used subs and everything but they worked yesterday. I turned my volume up to like 40 out of 50 and they just stopped working in the middle of a song.. HELP PLEASE?
Old Oct 22, 2007 | 12:38 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: WTF HAPPENED? SYSTEM
FUSE?
Old Oct 22, 2007 | 12:44 PM
s0ulj3r's Avatar
i dont think thats it i checked it.. its not blown
Old Oct 22, 2007 | 12:47 PM
95civic1.6l's Avatar
Did you check the amp to see if its getting power? you should do that first.then go from there if it is. then its either the amp or subs. If it isn't getting power than its the wire and or fuse holder. Sometimes the fuse holder gets loose and you will have to put it back on there and tighten it. That is only if your fuse holder isn't built into wiring.
Old Oct 22, 2007 | 12:51 PM
s0ulj3r's Avatar
could my power wire be bad? i checked my fuse and its connection to the wire and they seem fine.. my amp doesnt seem to get power because my blue neon isnt firing up.. could it be something with my remote wire..? i checked that also and its on tight and it is on the amp too?? wtf is going on?
Old Oct 22, 2007 | 12:55 PM
does your amp have lights on it to tell you if it is getting power and if it is in safety mode??? did you check your ground wire????
Old Oct 22, 2007 | 12:58 PM
s0ulj3r's Avatar
my ground wire isnt like 200% screwed on but its on, should i screw it on or just leave it how it is, it stays connected its wedged into a bolt holt that holds the extra spare. but yes my amp does have a light, but ive never seen "safety" mode on it yet.. This is my first system i've ever wired.. my bad
Old Oct 22, 2007 | 01:02 PM
s0ulj3r's Avatar
http://www.bestbuy.com/site/olspage....ci_sku=7652444
thats my amp, and im using 2 alpine type e's but one doesnt work anyways
Old Oct 22, 2007 | 01:03 PM
your fuse holder may seem fine but if you can pull on it and it will pull out it may not be good right now and you need to re twist it. When you screw the bolt into the wire the wire will start to pull itself apart. I've had that problem before. Check both sides. And if the light is on though and its green then it should be working and its your sub connection if its not on then its the wire and check what i just said.
Old Oct 22, 2007 | 01:08 PM
s0ulj3r's Avatar
should i disconnect my ground wire before i check this **** out..? i think thats what im suppose to do right?
