Best cleaner for only a $1
I have found a cleaner that will clean just about anything. engine grease, rims, carpets, windows, dashboard or anything plastic, well it will clean just about everything. Spray it on your rims just as you get to the car wash let it sit for a min or less and as you spray your car those rims will look brand new and even use it on a dirty engine that hasnt been cleaned in years and it will make it look brand new, i swear by this stuff you can get it at your local doller store its called LA's Totally Awsome All Purpose Concentrated Cleaner, it comes in a yellow bottle, they have a full line of products you should check out while your there but this stuff is awsome just follow the instructions on back for adding water for the type of cleaning power but most the time i use it straight but dont use straight cleaner on windows it leaves a weird dried chemical whitch is a little hard to get off but not bad for $1. go down to you doller store buy some and let me know how it goes.
i dont use it on the entire outside car as a soap i just use it for my rims, engine, interior trim and spot remover for carpet, it gets out stains in carpet better than any big name brand products ive used, and i just used it today when i washed my car and its probably the 6th times ive used it and still works like a champ and keeps my rims looken brand new. its got a logo saying "as seen on tv" and how could you say it sounds to go to be true when its only a doller.
