Energy Suspension Shifter Bushing Set Installation
4 Attachment(s)
Energy Shifter Bushings
1. Why would you want to do this? More precise shifting, more positive engagement, replace deteriorated bushing(s) 2. How long does this take? About 30-45 minutes. 3. Precautions? Use jackstands. 4. What's needed? Bushings 12mm socket socket wrench socket wrench extensions Step 1 - Jack up the car from the front We will be doing the smaller bushing first (next to the transmission) Step 2 - Remove OEM bushing Attachment 14001 -Shift linkage will drop down, pry out the OEM bushing with a screwdriver, and clean everything up with Brakleen. This is what you should have now in front of you. Attachment 14002 Step 3 - Installing ES Bushing Use the supplied lube around the edges... Attachment 14003 Push both sides into the shift linkage, insert metal shaft through the bushings (with lube on it as well), re-install shift linkage with the one bolt you previously removed. **Installation for the other bushing is the same.** Get under where your shifter is and you'll see this...remove the bolts, and then slide off. Attachment 14004 The shift linkage will drop again. Install ES shifter bushing with lube. (The two bolts were not re-installed yet in this picture.) Step 4 - Lower the car and clean up! You're done! Now hope in the car and go for a spirited drive. You will notice a difference. |
