97 ECU?
i got my car back from getting a lot of work done and i have come to a lot of walls in getting it running. but thats for anoother post. since i got my car back it has not been running. my headlights don't work but my brake lights work. the engine i was wondering if this is an ecu problem before i go and spend hours looking at other areas.my engine won't even make a sound let alone turn over and i also installed a new battery. please help
check your fuse box under the hood and see if your all your fuses are still food.. and also check the fuse box under your steering column to see if your fuses for your headlights are still there... its not an ecu problem... i think.. what exactly did you try to do to fix it???? was it running before???? what did you do to it to not make it run anymore???
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
