buddy club v-tec controler
has any body bought one of these ?
http://cgi.ebay.com/ebaymotors/Buddy...spagenameZWD2V if so any good or shall i give it a miss, i want to bring my v-tec in a bit sooner. |
RE: buddy club v-tec controler
Don't waste your money.
ya think those vtec controlers are crap?
i thought about geting one for my 94 so i could get the vtec to kick in at 4 - 4.5K rpms.... |
trust me... you don't want to screw with vtec engagement unless you have some pretty decent mods (forced induction or an aggressive cam are the two things that come to my mind)... Honda chose the vtec engagement point on each engine for a reason; it's not like they picked an rpm number out of a hat and used that.
And addiction, aren't you swapping a d16z6 in the 94? If so, vtec already engages at 4800rpm. *edit: whoops... apparently I can't spell "forced" correctly :) |
my 94 has a vtec as well. you can feel it kick in in my 94 and in my 99 i swear with that autotranny you feel slow until that thing kicks in :( stupid auto tranny! :(
Considering you can get complete engine management via CROME for less than a VTEC controller... yeah they're complete crap.
with the buddy club you get wat you pay for.if you get an apexi its more than just a vtec controller,if you want something to just adjust the vtec use a msd rpm switch with the rpm pills if your not running a car with the vtec harness and ecu if you got the vtec wired stock for vtec cars just get your ecu chipped
looks like i wont be getting that then lol
thanks for the advice, also regarding a chip, i have a mb6 1.8 vti which was only made for the european market ? i cannot find a company that lists a chip for it, any idea's please |
what do you need a chip for im not fimilar with the set up on those?
are they dohc or sohc? wat obd are they? wat car is it agian? if it is obd2 to get a chip you need a obd2 to obd1 jumper harness to run a p28 ecu then chip the p28 ecu if it is obd1 im sure a p28 chip will work all the same just diffrent name i think if the year is 2000 up im not sure at all on chips for those |
