d16y8 wiring harness and ECU
Old Dec 11, 2011 | 08:45 PM
96dseries's Avatar
Default d16y8 wiring harness and ECU
Hey guys, I'm new to the forum.
I have a 1996 civic coupe with d16y8 swap from a 99 civic.
the motor has the 99 harness on it right now and the guy just connected it to the 1996 ECU.
The speedometer & rpm is not working but the fuel gauge and temperature gauge are working.
It's also throwing a check engine light but I don't have a reader to get the code.
The guy says that I need to get a 1996 wiring harness and connect it to the 1996 ECU.
I'm thinking I can just get a 1999 ecu and plug it in to the 1999 harness that's in there right now.
Will a 1999 ecu work on 1996 shell?
Also, if not, can i just get the 1996 wiring harness?
Will everything work right with a 1996 harness & 1996 ECU on a 1999 d16y8?
someone please help, I have someone willing to come and install the harness. i just don't know if i should order it because I don't know if it would work on a 1999 motor.
Thanks!!
Old Dec 12, 2011 | 06:05 AM
So you have a 99 motor and harness, with a 96 ECU? The harness plug actually go into the ECU? I was under the impression that OBD2a (96-98) and OBD2b (99-00), had different plugs altogether. I dunno.
Get a 99-00 (OBD2b) ECU and you should be fine. ECU is easier to swap out. If there is actually nothing wrong with the sensors, the correct ECU for the harness you have should fix that.
Old Dec 12, 2011 | 08:58 AM
96dseries's Avatar
If i decide to go with swapping out the 99 wiring harness, and putting a 96 wiring harness in the car, with a 96 computer, will it work?
Old Dec 12, 2011 | 09:02 AM
You might have a few sensors that might not plug up due to the differences between obd2a and odb2b. I would look to see if there is information out there about it. I am sure there is. Look around on google, or honda-tech.com.
Old Dec 12, 2011 | 11:11 AM
FunkyFresh_EK's Avatar
Hi i did the same thing to mine to passed emissions.. i got a 96 hatch with a 00si motor swap.. i had to swap out my whole dash harness and floor harness to a 99-00 to work with a 99-00 engine harness.. its may sound like alot of work but actually not lol well maybe for mehahaha
since you got a sohc u can still use ur 96-98 ecu just make sure its an ex and manual
Old Dec 12, 2011 | 11:12 AM
might just be a broken cluster.. you might wanna check that out before you do anything
shangrila
Dec 30, 2007 04:48 PM
ScoobyAddict14
Mar 12, 2006 08:51 PM
FastFwd
Mar 11, 2006 03:08 AM
2000civicEX
Jul 22, 2005 10:00 AM
bain0005
Jul 6, 2005 03:51 PM
