DSM 450 Help
Old Aug 24, 2007 | 06:58 AM
  #31
Default RE: DSM 450 Help
clips are about $15 shipped
Old Aug 24, 2007 | 11:38 AM
  #32
FlipHKD720's Avatar
cool, just on ebay? I couldnt find any auctions with just the clips, it usually included the injectors or resistor box as well and i didnt really wanna pay for anyhting i alreayd had....
Old Aug 27, 2007 | 03:43 AM
  #33
check homemadeturbo.com
Old Aug 27, 2007 | 04:20 AM
  #34
2slo4u's Avatar
I think these might work
http://tinyurl.com/yqf92y
Old Aug 27, 2007 | 04:59 AM
  #35
FlipHKD720's Avatar
perfect, thanks alot Chris
Old Aug 27, 2007 | 11:14 AM
  #36
nik005's Avatar
so when ur wiring the box in do u only have to wire one of the 2 wires on the injector clips and the other one u leave alone that is if i was going to use the stock clips i would only need to cut one of the two wires on the injector right
Old Aug 27, 2007 | 12:46 PM
  #37
FlipHKD720's Avatar
if you were using stock clips, correct, whichever color is common throughout all the clips is the one you need to wire through the resistor box, but and once the wires go through the resistor box, then you can wire in the DSM cips
Old Aug 27, 2007 | 05:11 PM
  #38
nik005's Avatar
im still hopin that i can make the stock clips work when i finally get around to doin this
Old Aug 28, 2007 | 03:07 AM
  #39
Don't be lazy, and do it right. The more things you do correctly, the less **** you'll have to worry about malfunctioning later[:@]
Old Aug 28, 2007 | 05:07 AM
  #40
nik005's Avatar
well if they work then its right but if they dont then i guess ill have to go out and get me some dsm clips but this is a month or so from now so im not worrying bout it yet
