ecm problem please help!
Old Jun 3, 2009 | 03:51 PM
new_2_civics's Avatar
Thumbs down ecm problem please help!
Hi, i have an automatic 93 honda civic EX 4dr, that just wont start! and i think its either the distributor or the ecm. im looking into getting a new ecm and was wondering if anyone can tell me what all has to be the same. like can i put a 5-speed ecm on an automatic car? i had the engine replaced not to long ago and they put in a 1.5 liter, but when im searching for parts for my car it ALWAYS says they originally have 1.6 liter engines in them. so since its got a smaller engine in it than it originally did, do you think its messing with the ecm? any input would be greatly appreciated!
-thanks
Old Jun 3, 2009 | 04:34 PM
needs to have an automatic ECU. Find out your engine code. It's stamped on the front of the block.
Old Jun 3, 2009 | 05:04 PM
Post the CEL codes. Do you have spark? Does the fuel pump prime?
Old Jun 3, 2009 | 08:39 PM
RonJ doesnt the CEL light have to come on and stay on in order for the CEL codes to work? because it doesnt stay on goes away after about 5 seconds. no i dont have spark. and for the fuel pump, i have a keyless entry system on my car witch locks the doors after i turn my car over and unlocks them when i turn my car off. so as im turning my car over to listen for the fuel pump, i hear the loudness of the main relay, then the doors lock. so im not entirely sure if its making any noise because of all the other noises going on at the same time.
Old Jun 3, 2009 | 08:44 PM
i dont know if these will help but i grabbed them anyways.
Engine #: HM
D15B
2106786
ECM #: 37820-P06-A51
741-221253
VIN #: JHMEG8655P8046701
Old Jun 3, 2009 | 08:49 PM
I don't think there are any CEL codes.
Remove fuse 6 under the dash to temporarily disable the power locks. This way you can listen for the low humming sound of the fuel pump priming in the rear for 2 seconds when the key is turned to ON(II). Do you hear it?
How did you check for spark?
Old Jun 3, 2009 | 10:12 PM
ok i'll try removing the fuse tomorrow. i checked the spark by pulling out the spark plug tube and putting a screw driver in there to see if sparked and it didnt.
Old Jun 4, 2009 | 05:54 AM
Not sure how reliable this method is, but it surely runs the risk of blowing the coil if it wasn't blown already. Click the Spark link in my signature. Test a plug this way.
Old Jun 4, 2009 | 03:48 PM
the cars not close to me so the more information i have when i go over there will be better for the best result! so RonJ what should i do if i hear the fuel pump? and what should i do if i dont hear it?
Old Jun 4, 2009 | 08:00 PM
If the fuel pump doesn't prime, then check whether fuse 31 under the hood or fuses 18 or 24 under the dash is blown. If not, then check the main relay, which is the most common cause for the fuel pump not priming. If all this is fine, then the fuel pump or wires between the fuel pump and main relay should be checked.
If you indeed lack spark, check the coil and igniter unit in the distributor. Another possibility is that the timing belt snapped.
If you happen to lack both fuel and spark, then check the important ground wire on the thermostat housing. It may be loose, disconnected, or corroded.
