ecu
Old Oct 6, 2007 | 04:26 AM
lew1's Avatar
Default ecu
hi there i am new 2 the site so hello i am need of some help i have a 1997 civic coupe which started life as a 1.6 non vtec (d16y7) but somebody has dropped a 1.6 vtec in it (d16z6) .the problem is they havnt changed the ecu so the vtec dosnt work and i think it is affecting the idle. i am wanting 2 know if the proper ecu (which i believe is the p28) will plug straight in or will i hav 2 change the wireing loom. thanks
Old Oct 6, 2007 | 04:58 PM
Default RE: ecu
welcome to the forum! I'm fairly certain the p28 ecu (you were right... the z6 has a p28 ecu) will plug right in.
Old Oct 7, 2007 | 06:54 AM
lew1's Avatar
Default RE: ecu
thanks i hope it does because it will make life a lot easyer ha ha do u know how much difference it will make to the power. it hit 100 bhp at the wheels the other week thanks
Old Oct 8, 2007 | 03:26 AM
Default RE: ecu
If it still has the '97 (d16y7) engine harness in it, you'll need an OBD2a-OBD1 conversion harness. You'll also need to wire it for vtec.
if they switched the engine harness to the d16z6 harness, it'll plug right in
Old Oct 8, 2007 | 06:50 AM
lew1's Avatar
Default RE: ecu
is there any way of finding outwhich wiring loom is in. i know that the vtec is not wiered up because the valve that comes out of the top left hand side of the block (which i believe is 4 the vtec) has no plug in it. but there r wires and plugs all over the engine bay with blanking caps on them so i ant got a clue what is 4 what thanks
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
