Ecu calibration
If you're only swapping the transmission then you can keep the ECU; BUT it's going to throw a code for the Automatic Transmission Lockup Solenoid. Same motor = Use same Maps.
NOTE: There is a way to disable the Auto Function (Disable Code Easily). See www.pgmfi.org (site not loading for me at the moment.
apoplectic1
May 26, 2011 08:34 AM
theShamgod
Aug 15, 2008 02:48 PM
Imran
Dec 29, 2007 08:11 PM
You will need to swap in a 5 speed ecu.
