ecu problems
Old Jul 15, 2005 | 04:13 PM
90civicnj's Avatar
Default ecu problems
what would cause my ecu to lose electrical powerneed help its driving me nutsssssssss[]
Old Jul 15, 2005 | 04:19 PM
90civicnj's Avatar
Default RE: ecu problems
also my car will turn but wo
nt start sometimes. could it also be my dist. going bad im stuck as what it could be when it does this my ecu works and put out code#16 only does it once in a while please some helpme
Old Jul 15, 2005 | 04:29 PM
Street Sniper's Avatar
Hey, welcome to the forum, Man. Sorry about your troubles. One of my buddies had a trouble code 16 just last night and it turned out to be the connecter on one of his injectors. Apparently it just popped off. Check all of your connections to all of your injectors. No connection- no fuel to that cylinder.
ECU trouble code "16"
Fuel Injector System
defective circuit or unplugged / defective fuel injector
Let us know if they are all secure and you still get the code.
Old Jul 15, 2005 | 04:35 PM
90civicnj's Avatar
the connectors are fine there not losse or anything its just that when the car does this that it wont start thats the code it puts out get it started an the car will run fine for a couple of days or a week or so with that code. car runs fine its just the prob with it starting sometimes. could my dist be the problem or something else with the starting problem. also wre could i get cheap ho alt.thanks could use all the help i can
Old Jul 15, 2005 | 04:41 PM
Ok, first, can you please use punctuation? It makes it very difficult to understand what you are trying to say with one big run-on.
Now, I have never had a "16" but since the ecu is telling you that it's a "defective circuit or unplugged / defective fuel injector," I would take it's word for it. That injector may be bad or have a pintle stuck. It could be as simple as a bad connection. After you checked/wiggled/tightened all of your connections did you reset the ecu to see if the code came back?
Old Jul 15, 2005 | 04:46 PM
90civicnj's Avatar
yes. the code comes back only when the car decides not to start.right now my car wont start.the ecu has no power.engine turns but wont fire.
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
