ECU question
Old Apr 2, 2005 | 03:50 PM
rzimmer11's Avatar
Default ECU question
I just swapped a gsr motor into a 94 civic. Now theirs no wiring on the harness for the knock sensor and the ecu is recognizing it and throwing a knock sensor fault code. I know that when you throw a fault code it cuts your ecu back into safe mode resulting in a loss of power and terrible gas mileage. Does that same thing still apply with something as small as a knock sensor??
Old Apr 2, 2005 | 11:09 PM
cdn86gt's Avatar
Default RE: ECU question
The knock sensor is not an electrical load, it actually produces it's own voltage. Your ECU is looking for a variable voltage from the sensor. So in short yes.
Old Apr 3, 2005 | 12:36 AM
sacicons's Avatar
you should run a wire to the ecu. its a pain to get the pins in, but it can be done. try to get a harness that plugs into the ecu from a junkyard, then take it apart till you can get a couple of pins out, then splice the new wire to the pin.
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
