Fuel Injectioner Sensor.
Old Apr 27, 2005 | 01:47 AM
Cappelle's Avatar
Default Fuel Injectioner Sensor.
I am in the middle of a swap and i got stuck. haha it's been a little harder then i thought. anyway i am putting a ful system from a del sol in my civic the engine i am putting in is a d16z6. well i got to hooking up the fuel injector and it's diffrent. On the del sol one there is a "Sensor Assy. map" on the top of the fuel injector and on the old one it is mounted on the car. they are little diffrent too new one is a SV PS-30 old is a SV PS-22. I am not sure just what to do. the old one has a wire running into the car like under the dash it looks like. and the new one just has a wire running into the fuel injector itself. also the older one had a tube from the injector running to it new does not. So if anyone knows what would be the best way to fix this problem that would be sweet. i am not good at all with this part of it.
thanks
PS sorry if i am confusing i am crapy at spelling
Old Apr 27, 2005 | 05:24 PM
Cappelle's Avatar
Default RE: Fuel Injectioner Sensor.
any one have anyideas? i am really not sure what do do with this problem.
Old Apr 27, 2005 | 06:23 PM
Cappelle's Avatar
Default DIffrence you think?
Well does anyone know if there woud be much of a diffrence between PS- 30 and the PS-22 because it may be easyer to use the older one but the if the newer one is betterthe old one was runngin my stock Civic DX and this one is off a Dol Sol is it's diffrent but i am wondering if maybe the older one could handle the engine just as good as the newer one seeing as how it does not seem to be wired for the newer one
Old Apr 27, 2005 | 08:36 PM
Cappelle's Avatar
not sure if there is a diffrence still bu i got the old one hooked up and it seems to be worken fine
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
